Forum: Old versions
Topic: skins for mac - Page: 1
Is their only one skin for the mac . All the other skins say they are window files?
geposted Sun 18 May 08 @ 6:03 pm
Take alook at DJ formats skins they have mac downloads more to come soon.
I have uploaded some converted skins for use with mac.
Maybe in a few days will be available.
We have an official procedure for packaging the skins for the mac i will need to do this to ensure security.
Thanks for your help though.
I read below to look up DJ Formats Skins. But all is find is EXE. files. Is there a separate link or search feature for skins?
i downloaded the mac version of the scratch 5 skin and when i try to use it it says invalid skin file (error line 0 in the xml).
can anyone help me with this?
Please purchase the program if you like it , if you have please activate your serial in your profile.
This is how you get the great addons and free updates.
Hope to see you with us soon :)
Of course i have used the official procedure, uploading it in the official site.. here in VDJ.com
I hope the teamers put those skins available for download, and so the mac users can have more skins.
The other way it's to have a windows system, and ... convert it!!
I'll never try to do wrong things in this comunity.
How do i know wich ones of the skins in the download center work with mac???
any skin with this logo is available for mac click it for the DMG download.
Its a shame there are just a few. But thank you anyway!!!
Hey nobody really answered Diamond's question.
!i downloaded the mac version of the scratch 5 skin and when i try to use it it says invalid skin file (error line 0 in the xml).
I am getting the same message after I download a Mac skin. CAN anyone here help?
which skin have you downloaded?? can't seem to find scratch 5 in the download section. please post link.
Not sure if you are responding to my post, but I tried downloading New style VJ v2.1
Yes i was mate - lol
I have just downloaded this skin and it works fine. Couple of things to check - leave download ZIPPED - ensure you drop it into "VirtualDJ/Skins" and it should be fine to load in VDJ. The skin however hasnt been ported correctly for mac and the fonts are too large and do not work properly.
Can i suggest one of these that i have made specifically for mac (and then adapted for windows:
https://virtualdj.com/addons/6629/Mac___Win_VJ_variations.html
https://virtualdj.com/addons/6905/TouchSkin.html
https://virtualdj.com/addons/6680/MacSkin.html
https://virtualdj.com/addons/6916/RMX_Video.html
Also there is this one i am working on at the moment that should be ready soonish:
https://virtualdj.com/forums/105316/Virtual_DJ_Skins/MultiPannel_Skin.html
Obviously make sure you download the Mac version and not the windows one......
Hope that helps mate.
Cool, Thanks man.
please help! i have to play tomorrow and mi virtual dj 6 just show up the error: invalid skin file (error line %i in the xml) i have 8 hours trying to fixed and nothing. please help!
I am using Virtual Vinyl (Verion 6.0.2) on a 17" Macbook Pro .... It works a like a charm .... I am trying to get a new skin for it . Grom the VDJ.com site (Yes ,I am an active member !!) and downloaded a skin from 1 place and also a ZIP file with many skins however when I click on them to open it tells me " Virtual DJ cannot be found" !!!!
How do I install MAC skins (i am looking for one that looks like Serato Scratch Live)
Dan
You must have moved the Virtual DJ folder from it's default location. I had the same problem but there's a workaround instead of having to move the Virtual DJ folder back to where the installer thinks it should be. Just create a new folder "VirtualDJ" in put a sub-folder in it called "Skins". Now when you install a skin it will show up there, then just move the zip file from the 'dummy' skin folder to the actual skin folder.
Can you please be oa little more specific ? I'm not sure I fully understood WHERE to create these new folders (Virtual Dj and Skins) ???
87%
