Can i have that?
( http://www.numark.com/dxm01usb ) DXM01USB + Hercules RMX + 2 timecodes
And second, can i invert the fader and the crossfader? I know I can do it via mapper, but i am asking about invert ,for example, if you are using only virtual dj when you move the fader with the mouse.
Thanks.
Thanks.
geposted Mon 19 May 08 @ 10:18 am
You don't need DXM01USB if you gonna get RMX console. You forgot you will need VDJ Pro license also ;)
If you want to invert crossfader on the skin, you will need to edit skin to be able to do that.
geposted Mon 19 May 08 @ 10:58 am
I know i don´t need the mixer but i ask if i can add it too, just for know.
I have heard that you can have a discount when you buy the virtual dj pro if you have bought hercules rmx, what it the version of the virtual dj when you buy it?
And how can i edit the skin?
Thanks.
Thanks.
geposted Mon 19 May 08 @ 11:17 am
Thanks.
Thanks.
It's always good to have an external mixer and decks anyway in the event of a software/ computer error. I would think that setup should work. Yes, RMX users are entitled to a discount on pro, which is currently on v. 5.0r7, but future updates are always free. You won't want that skin once you go pro, there are much better ones available for pro users;^]
geposted Mon 19 May 08 @ 11:28 am
Thanks.
Thanks.
If you buy VDJ without RMX console you will pay the full price. It's better to get RMX first, than buy VDJ Pro.
If you want to edit skins, check Skins Forum, there is Tutorials.
geposted Mon 19 May 08 @ 11:33 am
