Freeze (date=805162302, version=5.0.7, build=507, thread=SortThread)
Crash ID=4fd88ecb (date=805201829, version=5.0.7, build=507, thread=Video,
dump=ff50085e, excode=c0000005 (0,8))
geposted Tue 20 May 08 @ 12:29 pm
Crash ID=4fd88ecb
>> It's an external crash linked to Video.
Check your video drivers + DirectX version
It can be a crash in a video codec too
geposted Tue 20 May 08 @ 1:17 pm
Could the problem has to do with xp and graphic card 1024 mb
I tried already two different ati and two different nvidia
now I have a 8800 GT 1024 mb ddr3
should i go for vista
all my drivers a the newest i can get!
geposted Tue 20 May 08 @ 3:41 pm
Yes, Vista is recommended for Video use.
[djce] But Windows XP can perfectly work with video too. You are not forced to buy Vista
geposted Tue 20 May 08 @ 4:06 pm
If you have already tested different video cards, I would suggest you to verify your video codecs. It could be the common problem.
geposted Tue 20 May 08 @ 4:16 pm
You are right Cel, XP can do video too.
I suggest using K-Lite Codec pack, it's free and has all you need.
Update DirectX also.
geposted Tue 20 May 08 @ 4:21 pm
Thanks all for your help. I give the codec pack a try.
geposted Wed 21 May 08 @ 12:07 am
I have done this after 7 hours of video playing virtualdj freeze again. I couldn't close the programm!
Here are my system:
AMD Athlon X2 5600+
3072 Ram
Controller: Numark DMC 2
Grafikkarte: Nvidia 8800 GT 1024 MB-DDR3
Soundkarte: M-Audio Delta 1010 LT
3 Maxtor One Touch III Hardrives with Firewire 800
I got still the problem that i have to change tv reselution to get the signal on the tv.
There must be still something wrong....
Here are my system:
AMD Athlon X2 5600+
3072 Ram
geposted Wed 21 May 08 @ 11:28 pm
