I reinstalled Vista & VDJ after an unfortunate disc partition experiment went wrong. Not a big deal but . .
Last night while I was working, VDJ just kept performing random 'backspins' while songs were playing.
It happened about 8 times in 4 hours. After the backspin, the song just continued as usual.
Anyone know what's going on here?
Gary
Gary
geposted Tue 20 May 08 @ 3:17 pm
did peeps think it was part of the show? : )
geposted Tue 20 May 08 @ 3:18 pm
I know it's not really funny while you are working, but I guess you had a laugh. I would. Did you have the backspin effect up in the effect bar of the skin.
geposted Tue 20 May 08 @ 3:30 pm
Well the first couple of times they did, but after a while they thought I was just being silly. I really need to cure this problem lol
Yes, the backspin was the effect that was loaded, but it wasn't activated. I do have a keyboard shortcut but I didn't use it. " of the times it happened I wasn't even in the same room as the laptop!
geposted Tue 20 May 08 @ 3:32 pm
Dumb question, were you typing when it went off?
geposted Tue 20 May 08 @ 3:40 pm
No, I wasn't typing. Sometimes I wasn't even in the DJ booth!
geposted Tue 20 May 08 @ 3:43 pm
Gary
Gary
Did you have timecode enabled as input? If so, and mic was on, the above phenomenon can happen :)
If not, some sort of controller thats drivers arent reinstalled after your HD crash?
Or backspin plugin activated by it, randomly..
Do some testing, I'm sure you'll find the devil :)
geposted Tue 20 May 08 @ 3:47 pm
