Hello all :)
Sorry if I'm being really think but is there a way to set up the Hercules Mk2 so the Volume cuts off at a sharper rate. When using external mixers in the past, the volume fader seems to be more responsive than the Hercules MK2 console.
Hope you can understand where I'm sort of coming from!
Thanks, Martin
Thanks, Martin
geposted Wed 21 May 08 @ 10:49 am
You can change fader rates via MK2 mapper but it is for Pro license users only.
geposted Wed 21 May 08 @ 11:52 am
So I'm stuck if I don't get a pro license?
geposted Wed 21 May 08 @ 11:54 am
I think you have General MIDI section in which you can map MIDI commands for MK2. But yes, it is easier with the mapper. Another benefit for going Pro.
geposted Wed 21 May 08 @ 12:28 pm
If he's using the LE version he cannot use anything else besides the native form. The software will not even load if the MK2 is not hooked as a controller.
geposted Wed 21 May 08 @ 3:13 pm
Thanks Fatkaz, I never used Home version.
geposted Thu 22 May 08 @ 11:23 am
