Hi,
I recently purchased one of these from Ebay which turned out to have a fault when using the headphone, however, between myself and the seller I managed to get a replacement under warranty which works apart from when I am using the jog wheel to setup a track (whilst another song is playing) you get interference through the speakers. This is also the same if you use the volume sliders and cross fader.
I am using the version of VDJ that comes with the unit and the 2008 drivers from Hercules.
Had a scout around this site but unable to find a similar discussion.
Any help greatly appreciated.
geposted Wed 21 May 08 @ 1:54 pm
Don't know what version of VDJ your using obviously but the first thing I would try is an isolator.
geposted Wed 21 May 08 @ 3:27 pm
I'm using VDJ3. Can you suggest where I can get an isolator from?
Thanks....
Thanks....
geposted Wed 21 May 08 @ 3:41 pm
Go to your local electronics store or car audio. It also may be your setup. If you have a decent computer. Set your performance tab to the left. Are you using TTs, If not go into your MK2 desktop and make your not in asio.
geposted Wed 21 May 08 @ 4:29 pm
Intersting... I just picked up a Total Control and hear interference when usingthe controls. I am using VDJ Pro 5. The controller is only connected to the pc via USB. It even happens with just the laptop speakers so no place to insert a isolator...
geposted Fri 30 May 08 @ 11:52 pm
Your problem comes in Performance, you can try lowering Performance tab in settings and disable Overclock and Safemode. Is it the same when you use sliders and knobs on the skin?
geposted Sat 31 May 08 @ 8:59 am
I will try the performance settings. The noise does not happen with the software sliders. I returned the Hercules and bought a Numark DMC2. Will be delivered tomorrow.
geposted Tue 24 Jun 08 @ 1:28 am
