Forum: VirtualDJ Skins
Topic: Virtual DJ 5 Default "Full" Skin in 1280x800
Does a version of my favorite skin exist in this slightly wider size to fit my monitor (1280x800)?
I use the "Full" one as it's just got everything i can't monitor on my controller.
It would be great as it could untilise the space more at look better in fullscreen, ie not stretched.
geposted Thu 22 May 08 @ 7:13 am
Just wondering if my the lack of help was due to my lack of pro licence?
Well I have one now and i'd really appreciate it if anyone could give me a hand?
Have you thought about using a Cue Skin, IMO they look better.
I've used this one. And it's a good skin to work with.
Cioce Cue v1.5, 1280x800
Also DJ Formatt's Mixlad series of Skins are good aswell, they come in 1280x800.
jimmy b wrote :
DJ Formatt's Mixlad series of Skins are good as well, they come in 1280x800.
Respectfully Jimmy...they are the best skin...IMO...but yes they are sized to fit that resolution...
I think I'm going to have to agree with you on that one mate.
Thanks jimmy b for the support, v1.6 is work in progress and it will rock ;)
The two jimmy suggested aren't bad but the reason I like the "full" skin is for it's simplicity whilst still having everything I want to monitor.
Those other two have alot of rubbish and stuff I can read off the Total Control that makes it seem a bit cluttered.
For example i have no need for an internal mixer as I have the real thing right infront of me...
Got any idea when mate?
Sorry Dave for Hi-jacking your post
Is top secret man, probably next week my skin will be available ;))
Cool, I will be certainly looking out for it then mate :)
I use the Turntablist with my Timecodes. It's a very good skin for it, ( first one in cstrol list)
For Turntablist DJs my skyn is not so indicated, it's good for DJs with compact controller ;)
Them some hot skins boy! ;)
you can also try this one is you like simple https://virtualdj.com/addons/skin.html?id=4190
nothing really on screen since you have it all on your controller. there is a TC active button right in the center of the spinner and also you can reset the pitch by clicking once on the LCD pitch% for slow reset or double click for instant reset.
But getting back to the original topic:
Default "Full" Skin in 1280x800 (vdj 5)
is it available somewhere or not? can the "auto resizer" create it?
JeremK is working hard on a resizer intended to do the job...Patience ;)
You can find the post in this forum to see how things are going. Besides, these default skins are not going to be very useful with the new features of 5.1.
