Just registered here, so first I would like to say hi to all members.
I have just downloaded Numark CUE 5 to evaluate as I want to mix videos. Everything works fine (wmv, divx, xvid, mpg, etc) except for Matroska (mkv) videos where the audio and video are out of sync and often the video freezes but the sound continues to play. I can play mkv files OK in other appications like Windows Media Player, Nero ShowTime, etc, but they are not OK in CUE 5.
I would be grateful if anyone can advise on this issue, before commiting to buy the product, as I have a lot of mkv files.
If its possible to convert mkv to xvid then I would also like to know the procedure.
Thanx in advance,
DJ Rob.
Thanx in advance,
DJ Rob.
geposted Fri 23 May 08 @ 10:37 am
Hi Rob,
Have you gone into the config menu of VDJ and added MKV in the codec section?
Gary
Gary
geposted Fri 23 May 08 @ 11:22 am
Thanks for your reply.
Yes, I had done that, the files were playing but just out of sync.
I gave up on mkv and converted them all to avi (xvid) using 'River Past Video Cleaner 7.7.1' which has done a great job and the quality IMO is as good as the original mkv files.
DJ Rob.
DJ Rob.
geposted Fri 23 May 08 @ 12:10 pm
I am having issues with .mkv videos too. It is not so much a sync thing as the frame rates in vdj are not smooth. They look fine with vlc media player. I have been converting these files to .avi and they play better but I do see a reduction in quality. I have the codecs installed and I added mkv to the list of codecs in vdj, is there anything else the vdj staff or I can do?
geposted Fri 10 Oct 08 @ 11:03 am
I've found that some mkv files don't play well, but most do. I've yet to dig into whats up with those files though...
geposted Fri 10 Oct 08 @ 8:52 pm
i havent lurked so i'm not sure if anyone has suggested this but to solve the stuttering frame issue in vdj/cue i just remux .mkv to .mp4 which is quite simple.
first you use mkvextract, which comes with mkvtoolnix (i think) here http://sourceforge.net/projects/freshmeat_mkvtoolnix/.
that should break you mkv down to audio and video streams.
next you join them together by putting them both into yamb, http://kurtnoise.free.fr/index.php?dir=Yamb/, and tell yamb the framerate for the video (very important because yamb assumes 25 fps and if your video is different you will completely lose sync).
after you run yamb you will have an mp4 that should play fine in vdj without transcoding.
note: this will not work on mkv's with variable framerates!!!
geposted Sat 09 May 09 @ 12:11 pm
