Please help me. I am really desperate.
I was first using Windows XP and Virtual DJ v.5 and the loops worked perfectly.
And then I installed Windows XP again on my computer, with SP2 and DirectX 9.0c.
But now when I install ANY version of VirtualDJ, the program recognizes that there is a
loop but it won't play! I use the "pro" skin intergrated into VirtualDJ (the fourth skin I think in the "Skin choosing" menu).
I installed 4 or 5 versions but none of them plays the loops.
So what is wrong?
geposted Wed 28 May 08 @ 1:40 pm
If you bought license, enter it in your profile.
Support software that you use ;)
geposted Fri 30 May 08 @ 9:20 am
Sounds like you might have installed a crack version in th past and it is now wreaking havoc with your newer versions.
Clean your registry, and D/L the demo for this web site. give that a try.
geposted Fri 30 May 08 @ 11:10 am
It doesn't work.
Tnx for the help anyway.
My uncle gave me this as a gift, and it was burnt on a CD (dooh...) so I cannot really do anything with it.
geposted Tue 03 Jun 08 @ 3:17 am
