paidia thelw epigontos voithia...
tis proalles evala tous kainourious drivers, kai ekanan ypdate k sto firmware tou hercules...
twra exw provlima, exw to virtualdj 3.1 pou eixe mazi me ton player, kai den exw akoustika... to idio kai sto 5.... einai megalo provlima.
sta akoustika vgainei sto mix mono i mixi, kai sta ypolipa tpt.(A, B)... prin to update to eixa monima sto mix, kai aytomata molis fwrtona tragoydi, pigene kateythian sto monitor kai to akouga...
den xerw ti na kanw, einai megali anagh...!!!
(ase pou sto vitualdj to vlepei san to aplo to hercules k oxi mk2...)
geposted Thu 29 May 08 @ 7:32 am
giati den vazeis ksana tous palious drivers? Oi teleutaio drivers (pou kanoun gia vista) exoun dimiourgisei poilla problimata apo oti diabazoume apo dw kai apo kei.
geposted Thu 29 May 08 @ 9:15 am
to provlima einai pws ua gyrisw styo proigoumeno firmware... kai me tous palious drivers, to idio gynete....
geposted Thu 29 May 08 @ 9:25 am
yparxei kapoia sygkekrimeni diadikasia pou gyrizeis stous palious drivers, den einai apla tous vazoume, kaneis mia seira apo kiniseis, vgazeis prwta tous palious (ekei einai to dyskolo) den to kserw poly kala, o aledjo to exei kanei, des kai edw https://virtualdj.com/forums/65577/Greek_Forum/Einai_ilithioi_i_oxi_.html?highlight=vista%20drivers%20hercules
Aledjooo ..gia voitha to paidi ... kai ase tis gkarsones isyxes...xexexe
geposted Thu 29 May 08 @ 11:49 am
to diavasa to post, alla kai me tous palious drivers den exw monitor... to thema einai twra ti kanw? to evgala axristo(giati xwris monitor...) to mk2 me to firmware update?
geposted Thu 29 May 08 @ 12:07 pm
kai paratirisa molis twra episeis oti oles oi exwdoys pou exei to mk2 paizoun to idio pragma, oti kai na epilexeis...
k episeis otan paizei to ena deck kai paixeis to allo xwris na sikwseis entasi akoygete poly ligo eksw...
geposted Thu 29 May 08 @ 12:16 pm
xexe skeftomai na pao na doulepso stin mega-etairia hercules kai na gino apoklistikos antiprosopos stin ellada.
loipon, tha katebeis kai tha ekgatastiseiss tous drivers 2006 kai tha kaneis ta eksis bimata:
1) Kill the HDJ2CPL.exe in taskmanager.
2) Click Start, Run and type in "c:/Program Files/HerculesAudioDJ
Console Series/Mk2updater/hdj2updater.exe" -manual and click OK. (slashes other way, but the forum don't allow them). This opens up a flash tool for the firmware on the console.
3) Hold effect button 1 + 2 + 3 at the LEFT deck pressed down at the same time, and KEEP them pressed while you reconnect the usb cord to the console.
4) The firmware flash window should show "boot" for firmware controller if sucsessfull.
5) Press the Ctrl button at lower end, and choose the file "HDJ_PSOC1.djc"
6) Make sure there is a check mark in the Flash for the Firmware controller and press update!
if the Sound Section Fails
1- Disconnect the Console.
2- Shutdown the system. (Restart will not do, make sure to completely
shut it down)
3- Turn it back on.
4- Once completely restarted, close the MK2 mixer on the taskbar. If it
isn't there click Start, Run, type in taskmgr then click ok. Go on the
Processes tab and locate the HDJ2CPL.exe right-click it and choose end
process then click Yes on the warning message.
5- Click Start, Run and type in "c:Program FilesHerculesAudioDJ
Console SeriesMk2updaterhdj2updater.exe" -manual and click OK.
6- Hold talkover button on the console and reconnect it (make sure to
hold the button while plugging it back)
7- Now the DJ Console Mk2 Updater Firmware Controller should say boot.
Click the Open Ctrl... button and select HDJ_TUSB.dja file then click
Open..
8- Make sure there is a check mark in the Flash for the Firmware
9- Unplug the DJ Console and plug it back.
10- Check in the DJ Console Updater if a firmware is now installed.
11- Go in the Control Panel and then into Game controllers.
12- Go into the DJ Console Mk2 properties and move the treble knob on
the right side of the console. If it works your good to go, if it
doesn't repeat the procedure from section 7.
shut it down)
3- Turn it back on.
Open..
geposted Thu 29 May 08 @ 2:20 pm
Kala Aledjo me tetoiou epipedou Agglika tha se paroun sigoura ..xaxa
geposted Thu 29 May 08 @ 2:39 pm
wrea, thanks para poly, erwtisi, tha vgalw toyus kainourious prin valw tous 2006?
geposted Fri 30 May 08 @ 7:05 am
ta ypolipa apo to 1 ws to 12 einai an den ginei me ayta apo to 1) ws to 6) e????
geposted Fri 30 May 08 @ 11:01 am
paidia exw provlima, den egine tpt...
ekana update kai sto controler, kai sto audio apo tous drivers 2006, kai pali gynete to idio...
ti tha kanw? ta arxeia tou ergwstasiakou firmware den yparxoun pouthena????????
geposted Sun 01 Jun 08 @ 8:02 am
dokimase kai ena allo pou exo kanei ego.
bale win xp sp2 + drivers 2008 + vdj5.rev6
se mena douleuei
se mena douleuei
geposted Sun 01 Jun 08 @ 11:00 am
SOS
eixa paei na paikso sto party enos filou kai valame diaforous drivers klp.dn mas epaikse telika.toulaxiston litourgouse san karta ixou.to efera spiti kai epaize kai simera mou vgazei ena updater kai mou kolise ekei.ekana unistal instal...tipota.ekana kai unistal apo unistaler tipota.
dikimasa na kano auto pou lei o " aledjo "l
alla dn mou tin anagnorizei kan.to mono pou iparxei stin diaxirisi einai to HERCULES DJ CONSOLE MK2 Bulk
ti na kano????
ti na kano????
geposted Mon 29 Jun 09 @ 11:19 am
