I have numark cue and i'm thinking about selling it on ebay and buying the VDJ version (due to hc4500 issue). Anyway will I be able to unregister myself and allow someone new to reregister the program so that they can get the updates and so on?
geposted Thu 29 May 08 @ 8:10 pm
I don't think it's possible, I don't think the license is transferable.
I would just keep it and set up a new account/License and user name with VirtualDJ and download it.
geposted Thu 29 May 08 @ 8:31 pm
----- VirtualDJ End User License Agreement -----
(Also applies to all other branded products)
By clicking on "I accept" you agree to be bound by the following terms. If you don't, please click on "cancel", remove all copies and return the product to the place of purchase within 30 days of your purchase for a full refund.
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
2. OWNERSHIP
The foregoing license gives you limited rights to use the Software.
Atomix and its suppliers retain all right, title and interest, including all copyrights, in and to the Software and all copies thereof. All rights not specifically granted in this EULA, including International Copyrights, are reserved by Atomix and its suppliers.
2. OWNERSHIP
geposted Thu 29 May 08 @ 10:04 pm
Well that sorted out that little question then, LOL
geposted Thu 29 May 08 @ 10:32 pm
i guess it does...
geposted Thu 29 May 08 @ 11:29 pm
What issue with hc4500? VDJ and Numark Cue are THE SAME programs, and if something is not working on Cue, it will be the same on VDJ. I think that support for that controller is not perfect yet, so just a little patience.
geposted Fri 30 May 08 @ 7:46 am
Same here also, just registered my Home version from Cue and still waiting for the order I made for VV.
As Jimmy said just keep it, in which I would, then soon I'll register my Pro version of CUE (from VV).
Question: would I'll be a Home and a Pro user at the same time? e.g labels under my name Cue KCO / Pro...
geposted Fri 30 May 08 @ 11:46 am
Pro, just look at mine. <---
geposted Fri 30 May 08 @ 12:08 pm
Quick reply indeed...Thanks mate...
geposted Fri 30 May 08 @ 12:10 pm
Actually, from what I've read I believe the HC-4500 isn't natively supported on Cue at all at the moment?
geposted Sat 31 May 08 @ 6:48 am
That is right. Maybe in the future.
geposted Sat 31 May 08 @ 7:55 am
So if I sell my VMS4 to someone else the software goes with the controller then that mean the software have to be transfer over to the new owner.
It not like I'm going to use the VMS4 when I own a different controller or buy a new controller.
I think the terms needs to be rewritten because many DJs will end up selling the controller and upgrade their controller that may have VDJ.
It doesn't make any sense to not be able to transfer ownership when I don't have the controller the software was intented for.
geposted Wed 10 Oct 12 @ 8:39 am
The answer to your question is that NO, VirtualDJ does not permit the transfer of any software license.
But thank you for opening 4 year old post when there is a very active post on this topic already.
Please read here -- https://virtualdj.com/forums/169503/General_Discussion/Legal_and_safe_way_to_sell_VirtualDJ.html
Topic Locked
Topic Locked
geposted Wed 10 Oct 12 @ 9:50 am
