I have the Virtual DJ loaded and playing, where do I go to add my music from my computer?? Please help
geposted Fri 30 May 08 @ 6:55 pm
In the browser on the left side of the skin, you can open your folder and make it a favorite one also.
geposted Fri 30 May 08 @ 7:38 pm
the location of the buttons (i.e. samples,effects, config, files) wiill depend on what skin u r using, but they r usually close to each other plus when u set the cursor on any of them a message will pop up and let u know that particular button`s function look for the one that reads: audio files. good luck.
geposted Fri 13 Jun 08 @ 5:36 pm
