Forum: VirtualDJ Skins
Topic: Skin with 1024x600 Resolution?
I would love to have a 1024x600 skin for my Virtual DJ.
Can anybody explain how i can "resize" the Numark Cue 1024x768 Skin to my size?
thx
geposted Sat 31 May 08 @ 8:31 am
Just "bumping" this topic, as I need one of these as well
I've just brought the little 10" widescreen MSI wind to possibly use as a back-up computer, & the maximum screen resolution is 1024 x 600
I could with with a fairly minimal skin, as I want to keep as much vertical height as possible for the browser.
can anybody help?
IAN
I'm actually working on a 1024x600 skin.
It will be released tomorrow and I will write down the download link in this thread.
Excellent! :-)
....i'll look forward to that.
Hi is it possible to get this link uploaded, ive just bought a ADVENT notebook its tiny meaning the resolution is only 1024x600 really need this skin cos im playing a set tomoro night and this would make my night a hell of alot easier (not lugging round a monitor to plug in) or alternative could you email it to me ***@**.**?
Would be very much appreciated
Toby
[JeremK]: Emails are forbidden for no license users.
Hello Price iow
This skin is only available for licensed users of VirtualDJ. If you have bought VirtualDJ (Pro version, home version, or bundled version with a console), please enter your serial number in your profile: http://www.virtualdj.com/users/edit.html
Hey JeremK, the link to your 1024x600 skin is dead. Did it get moved?
Hi all,
First, sorry for my bad english.
I bought a Hercules DJ Console MK2 with Virtual DJ (virtualdj_djc_v3.4.1.exe ) and a MSI Wind. It works good. I registred the serial on virtualdj.com and I downloaded miniSkin.exe.
When I run it I have an error message :
"Software not found. You must install software first....."
Is this skin work with my version of Virtual DJ ?
Thanx for your answer.
Hello vicho
This skin isn't compatible with VirtualDJ 3.xx it is only compatible with version 4.xx and upwards.
That's why you are getting an error message.
You can try using the Skin Resizer Tool to resize a skin for your MSI Wind: http://www.virtualdj.com/addons/4442/VDJ_Skin_Resizer_Tool.html
You can also upgrade VirtualDJ to the professional edition. A reduction is available as you already own a VirtualDJ product.
You need to write your serial number at the bottom of this page:
Thank you JeremK, I will try Skin Resizer tool first.
Bye
Toby
when i start the .exe i receive this error: VirtualDJ not found!
why? i have it in my pc, i use it!
so i downloaded the .zip and copied to skin directory but there's another error: line 8
please help....
You've bumped an old topic with an off-topic comment. Please start your own thread, making sure to state exactly which skin you are using and with which version and edition of Virtual DJ.
