VDJ 5.1 is uitgekomen. Alle pro users kunnen deze versie downloaden via de "Download center" knop.
Aangepast in 5.1:
FAME engine:
- new BPM engine with more than 99.9% of correct detections
- new automatic Key detection
- optional automatic Key-Match
- new auto-gain engine
Video:
- video session recording
- fade to black on level sliders
Automix:
- display both playing and coming waveform in songpos graphic
- can move mixpoints on the fly during automix
Timecode:
- new engine "VDJ Timecode v5" for VirtualDJ vinyls, optimized for scratch (the old engine "VDJ Timecode v4" optimized for needledrop is still available)
- new engine "Noisemap" compatible with most noisemap-based records
- new engine "PCDJ" compatible with most miss pinky-based timecode records
External devices:
- Pioneer CDJ-400
- Vestax VCI-100
- Denon HC4500
- Xponent (fixed)
- DJConsole RMX (improved)
New functions:
- smart beat-tap (automatically snap tapped beat to the nearest likely bpm)
- smart play (play directly on beat)
- smart cue (hotcue always in the tempo)
Skin:
- new skin "HE5" featuring all the new functions of v5.1
Small Improvements:
- sharper coverflow
- improved vumeters
Bug fixes:
- many small bugs from v5.0.x fixed...
Note: De demo versie van 5.1 is nof niet uit deze komt meestal een aantal dagen na de officiele release.
Ewout
Aangepast in 5.1:
FAME engine:
Video:
Automix:
Timecode:
External devices:
- Pioneer CDJ-400
- Vestax VCI-100
- Denon HC4500
- Xponent (fixed)
New functions:
Skin:
Small Improvements:
- sharper coverflow
- improved vumeters
Bug fixes:
Ewout
geposted Sun 01 Jun 08 @ 11:46 am
Moeten we andere time code vinyl en cd gebruiken of kan het met de andere verder /
groetjes
Dimi
groetjes
Dimi
geposted Sun 08 Jun 08 @ 3:59 am
De VDJ timecode cds / vinyls werken nog steeds en zelfs beter met de laatste release. Dus je heft geen nieuwe te kopen / te branden.
Ewout
Ewout
geposted Sun 08 Jun 08 @ 3:14 pm
thxxxxxxxxxxxxxxxxxx
geposted Mon 09 Jun 08 @ 1:47 pm
hoi,
heb toch het gevoel dat de time code 4 beter werkt dan de 5.
heb zaterdag met ne denon 4500 gewerkt en met de 5 is hij trager weg en is het cue punt niet altijd juist dan dat ik hem ingesteld heb.thuis met de denon s3500 heb ik het ook.
4 werkt prima.
Dimi
4 werkt prima.
Dimi
geposted Mon 23 Jun 08 @ 11:51 am
Graag on topic blijven. Graag posten in een thread met hetzelfde onderwerp of een nieuwe aan maken.
Ik heb het gevoel dat het aan je instellingen moet liggen, want bij mij is 5.1 qua tijdcode beter dan de versies ervoor en dat zijn ook de geluiden uit de rest van het forum.
Ewout
Ewout
geposted Mon 23 Jun 08 @ 12:24 pm
