i wanted to know if anyone can help me out here, for some reason i put the time coded cd's in my dual cd player and when i hit play the song tends to skipp(hiccup) , i did some mods on the software but i still get the skip. i have a numark cdn35 dual cd player. But when i use my cdj800 it works fine, no skipping. im wondering what the problem mite be, Im useing a 2g / 120 gb hardrive laptop and it works awesome, but its just happens on my numark dual cd.
hope some can help.....
geposted Thu 05 Jun 08 @ 12:12 pm
Are you using the consumer grade timecode signal for the numark?
Cause CDJ's uses the pro timecode.
Hope that helps
Hope that helps
geposted Thu 05 Jun 08 @ 2:58 pm
