I have each deck of my VDJ on a separate channel going into my mixer, i used the VDJ fade control for video. Here is my problem, I'm playing an MP3 song with no video and I'm going to bring in a music video to play next, but while i'm previewing it or waiting, the video is outputting to the screens. I know if i fade it over to the MP3 deck that it wont display, but it also will not play the audio for the 2nd deck so i can preview it on my mixer.
Anyone have a suggestion on blocking the output until i'm ready?
I'm sure there is a feature for this, but can i output some kind of video effect for the mp3 file to cover it up?
geposted Thu 05 Jun 08 @ 8:11 pm
If you disable the main crossfader in VDJ and unlink it, you will be able to use your mixer to cue. Get what I mean. I use it this way and the only thing I am crossfading in vdj is the video as u use the mixer itself to crossfade the audio.
geposted Thu 05 Jun 08 @ 9:22 pm
Go into config>video and untick the "linked crossfaders" box.
geposted Thu 05 Jun 08 @ 11:21 pm
Excellent, thanks for the response!
geposted Mon 09 Jun 08 @ 2:32 am
Leave the crossfaders Linked in the Video tab. But the advice on Disabling the Audio crossfader is correct. Go to Config -> Options tab -> First Column - Crossfader set it to Disabled.
geposted Mon 09 Jun 08 @ 5:32 am
