I don't see the padlock button for Keylock anymore in the new skin? The manual for v5.10 is still based on the v5.07 skin.
I'm using v5.10 in combination with the DJC Mk2 with the march-'08 drivers. I noticed that the Master Tempo button on the console is the only way to use Keylock. Is it also possible with a skin button?
Also the Beatlock function in this combination looks only possible by hitting the 'B' key.
With v5.07 and the older console drivers I was able to modify the skin (by replacing twice sync to beatlock in the xml part: <button action="sync" chan="x" rightclick="auto">) so that the Master Tempo button on the console became Beatlock, but that trick doesn't seem to work anymore with v5.10 and the new console drivers. Also with v5.07 and the new console drivers, changing the xml for Beatlock doesn't seem to work anymore on the console Master Tempo button.
Who knows how I can get back the Beatlock function on the Mastertempo button of the console?
Also some older skins use Beatlock at the Sync button of the skin, is this possibe in the v5.10 skins?
geposted Sat 07 Jun 08 @ 7:54 am
The Home Edition 5 skin is NOT the PRO skin. When Home Edition 5 releases the manual for that product will be based on that skin. The PRO skins are the original 4 skins released when version 5 released.
Use your old skins, you are not forced to use the Home Edition skin.
geposted Sat 07 Jun 08 @ 10:36 am
Okay, I wasn't aware HE stands for Home Edition, but even with the standard skins my problem with Beatlock & DJC Mk2 remains. Any idea's?
geposted Sat 07 Jun 08 @ 11:20 am
Have you solved this problem? I'm experiencing the same.
geposted Thu 12 Mar 09 @ 6:26 pm
