I would like to upgrade to rev 7 but i need to know what are the bennifits or the differences between them and is rev 7 more reliable? All i spin is audio i don't care for video. Laptop specs is AMD Turion 64 dual core tl 56 1.8, 2gig of memory, ops windows xp, 500 gig ex hd western digital 7200 rpm.
geposted Sat 07 Jun 08 @ 12:34 pm
Do you use time code in any way? But I would always recommend upgrading as soon a new version comes out.
geposted Sat 07 Jun 08 @ 12:44 pm
As of right now i'm just using the total control. But i do plan on using time codes
geposted Sat 07 Jun 08 @ 1:12 pm
I also use a Total Control, with v5r7 it works very very well....I bet you experience no issues at all.
geposted Sat 07 Jun 08 @ 2:19 pm
yea but what is the difference beetween the two
geposted Sat 07 Jun 08 @ 2:22 pm
Ah sorry look here the very first post is from Steph. Best from the boss himself... ;-)
geposted Sat 07 Jun 08 @ 2:51 pm
One more question i have my performance tab set 1 left from best quality does this put more strain on my cpu or what is the difference between the fastest & best quality?
geposted Sat 07 Jun 08 @ 9:31 pm
Mine is set too fastest..and I notice no difference in my sound output....but I also use an external EQ....
geposted Sat 07 Jun 08 @ 9:54 pm
