Scratching with mouse don't working after skin name is changed. Please look at my video: www.radiojih.cz/files/VDJ.avi (1,7 MB XVID file) Any ideas?
geposted Sat 07 Jun 08 @ 7:08 pm
Why would you do such a thing during a gig ?? I see this as insignificant as it is impractical that you would do this during a LIVE session at a gig.
geposted Sun 08 Jun 08 @ 2:11 am
LoL, what an idiotic thing to do, and ask. More like a bad joke...
Ps., I cannot open Virtual DJ if I uninstall the Windows. Any ideas?
geposted Sun 08 Jun 08 @ 7:29 am
???????? idiotic thing? Are you OK?
@cstoll
Not during a GIG. I can turn off VDJ, change skin name, restart PC, start VDJ, select skin with new name and it is the same. My skin is correctly working only when his name is EXACTLY " !!!!!! Ludek New.zip" Nothing else. Very curious for me. :-O Is there any Temp in VDJ for older skins based at their names or what? I don't get it.
geposted Sun 08 Jun 08 @ 7:37 am
send me your skin -- cstoll [at] virtualdj [dot] com
I will take a look at it. But to answer your question - no, there are no Temp files created in a Temp folder.
geposted Sun 08 Jun 08 @ 9:25 am
I have never worked with skin creation, but could it be that the files inside the zip need to be renamed as well? Looking at all my skins, I see that the XML/BMP are the same name as the ZIP.
geposted Sun 08 Jun 08 @ 1:21 pm
I am, thanks for asking. It's stupid to rename only a zip file, while the .xml and .bmp have
another name. It's idiotic to do it while the program is running.
geposted Sun 08 Jun 08 @ 1:45 pm
another name.
another name.
Not always, here is an example:
VirtualDJ5.zip --> inside is 1024x768.xml and 1024x768.bmp, Skin name="VirtualDJ HE5"
Did you read my previous post? Again: I can turn off VDJ, change skin name, restart PC, start VDJ, select skin with new name and it is still the same.
BTW: stupid, idiotic - thanks, great words from you. If you don't want help me, shut up.
geposted Sun 08 Jun 08 @ 2:57 pm
Let me another offtopic post to explain myself:
I did read your second post, however your first post of presenting the issue
lacked the "logical part" to which my first comment was referring to. The way
you presented it was frankly ignorant from you (if you want another word).
Next time you open a topic and want help, describe the problem in detail,
what the issue is exactly, and what good does changing the filename actually
do in this case.
But since you only posted a video where you change an application's filename
while it is running and give no info at all... well what did you expect? It looks
like a joke.
geposted Sun 08 Jun 08 @ 3:25 pm
You can even delete ACTIVE skin from documents/virtualdj/skins/ while VDJ is running. No problem - VDJ with this skin is still working until next restart. Skin (xml and bmp) is unziped in the memory. You can try it. Renamed skin is activated after: config -> skin --> click on skin --> OK. That's why in my video is VDj still running.
geposted Sun 08 Jun 08 @ 3:47 pm
Just send me the skin --
geposted Sun 08 Jun 08 @ 5:35 pm
I sent you my skin yesterday.
geposted Mon 09 Jun 08 @ 5:35 am
