For some reason everytime i match the beats, they match perfectly and then after a few bars, they start shift backward and i loose the match.
pls help.
pls help.
geposted Sat 07 Jun 08 @ 11:05 pm
Check your performance tabs....also if you get your music recorded from a low end USB turntable this could occur. I have sometime experienced this and needed to un-plug and the re-connect my Total Control unit, so if your using an external controller you might want to try that.
geposted Sat 07 Jun 08 @ 11:12 pm
