Hello, I'm having problems with the automix feature on this version, I can't make a normal automix with 2 songs if the first song doesn't have at least 32 cbg's or beats before the outro or outgoing point.
Let me put this in a different way: If I set an outro cue point 16 or less cgb's (beats) on a song, when the automix starts, the sound disappears, the video mix can be seen and the sound comes back after 32 beats have passed. This didn't happen on VDJ 3.4, It was possible to set an outro cue point on any of last cbg's and the automix was fine.
Does anyone know some way to fix this, Is this possible?
Kind regards,
Octavio de la Mora.
Kind regards,
Octavio de la Mora.
geposted Tue 10 Jun 08 @ 8:20 am
Please do not make multiple posts of the same issue. You have already posted this elsewhere. We are looking into the issue.
Chris
VDJ Team
Chris
VDJ Team
geposted Tue 10 Jun 08 @ 9:02 am
I'm doing this because I haven't seen or received a solution in all of the forums and the last forum that I posted my problem is named "PC technical support", that's why I did it. Anyway, I'm sorry and won't happen again.
Kind regards,
Octavio.
Kind regards,
Octavio.
geposted Tue 10 Jun 08 @ 11:24 am
