Hi everyone, I am having a problem with virtual DJ's broadcasting function. I have set my router so ports 8000 are open on both UDP and TCP and people can now connect to me (finally!) but now I seem to be having the problem where people are only able to hear a few seconds of the stream. Its almost like its downloading a tiny section of the stream and then playing it back as a single file. It doesn't seem to realise it is a constant stream of music. Does anyone have any tips?
geposted Fri 13 Jun 08 @ 6:37 pm
try use port 80....
Probably some problem with connecting to your PC at port 8000
geposted Sun 15 Jun 08 @ 8:11 pm
Hello... I have this exact same problem and have been running around the whole net trying to identify this issue. I have tried switching ports without luck... and besides... when I change the port number on Virtual Dj it still shows that its the broadcast is port 8000. Can anyone help please? I am desperate..
geposted Mon 16 Jun 08 @ 5:27 pm
Any luck on this issue yet? I have encountered the very same problem and can't find a solution using google...
geposted Sun 30 Aug 09 @ 9:53 am
