Im using VDJ5.0.7 and Total Control. But I have problem is
There some noise ( distortion) appear while playing a track (good quality). Especially, when using faders.
Im using USB soundcard Creative Xmod for Master, and laptop's soundcard for headphone. Im sure the Xmod very good ( i mean its not broken or a old one).
How I can get clean sound?
Why There are static noise when turning dials or using the faders?
Do i have to buy Ground Loop Isolator http://www.radioshack.com/sm-buy-the-ground-loop-isolator-on-http-wwwradioshackcom--pi-2062214.html
tks
tks
geposted Sat 14 Jun 08 @ 2:06 pm
I would advise you to go into the Xmod control pannel and increase the latency setting , this card is more of a gamers card than a DJ card however.
You may need to use Asio4all to replace the default driver , you would choose :
Inputs : none
Outputs : headphones
Card : asio
driver : asio4all
Press Advanced and enable the xmod as the card you can then adjust the latency until it no longer drops out.
Kind Regards
Simon Bangs
Numark Cue Product Specialist.
Inputs : none
Card : asio
driver : asio4all
Kind Regards
Simon Bangs
geposted Sat 14 Jun 08 @ 3:55 pm
Tks for help
I will increase the latency setting and check it out tonight.
Beside this, My friend uses the Hercules control. And he has the same noise when mixing (like I got), even we set ASIO already.
So what yr recomendations?
geposted Mon 16 Jun 08 @ 11:06 pm
how do you get both sound cards to work with aiso driver
geposted Fri 09 Jan 09 @ 8:48 pm
