I'm wondering if there already is a Hercules DJ Console RMX skin, of if somebody's making one...?
The console version that came with it obviously has the looks of the RMX, but I'm using the Pro version right now...
Thanks
Thanks
geposted Mon 16 Jun 08 @ 4:30 pm
Hi Peter, u could still use ur console skin in ur pro version. Just select it in the config. U must copied the skin from ur console folder to the pro folder, then u can accessed to it;)
geposted Tue 17 Jun 08 @ 1:21 am
If you do what spinnaj has just said, the skin won't have some of the features that the full version have, but if you are happy using it, then there is no worries.
geposted Tue 17 Jun 08 @ 6:15 am
im will be make one for a client of mine, im finishing my skin before move to do his but I'll keep you post when it's done
geposted Sat 12 Jul 08 @ 7:54 pm
