why does it when i have two songs playing
and i want to kill the 'bass' on one of them
does it put the two tracks out of synch?
it happens all the time, and its VERY VERY
annoying.
any advice or reason as to what is causing
this?
annoying.
this?
geposted Sun 20 Jul 03 @ 7:19 am
are you using a keyboard shortcut to kill bass. If so check to make sure that this key does not have any other shortcuts assigned such as skip beat or scratch.
geposted Sun 20 Jul 03 @ 5:11 pm
nope, its just pressing the 'kill' button.
this usually happens too when the two tracks
are 'beatlocked'.
why would that change it tho?
are 'beatlocked'.
geposted Sun 20 Jul 03 @ 11:38 pm
