Update of deck A for mix lab 4.0
geposted Sat 05 Jul 08 @ 5:02 am
DJ FORMAT I suggest you to change the word "MIX" about haedphone_mix putting it on the middle of the slider (new improvement about VDJ 5.1) and you could write "MASTER" on the right.
Conclusively you could write
CUE<------>MIX<------>MASTER
geposted Sat 05 Jul 08 @ 6:36 am
Matt - will it also be the same way as in previous versions - right click on play to sync on wave form and not CBG? I really like that feature. As stated many times, not all songs (analog) alighn properly, no matter what you do. Cheers and great work.
geposted Sat 05 Jul 08 @ 9:41 am
Very nice indeed Matt...you are THE MAN!
geposted Sat 05 Jul 08 @ 10:34 am
YES M8 { UPDATE PIC }
geposted Sat 05 Jul 08 @ 11:32 am
Greet look - sheer genius.
geposted Sat 05 Jul 08 @ 1:18 pm
Lookin good, cant wait to try...
geposted Sat 05 Jul 08 @ 6:13 pm
so youre moving straight to version 4?
geposted Sun 06 Jul 08 @ 6:32 am
geposted Tue 08 Jul 08 @ 3:34 pm
How cool is that~!
geposted Tue 08 Jul 08 @ 4:02 pm
It Looks great :)
geposted Tue 08 Jul 08 @ 4:57 pm
Maybe you can let me beta test the new skin first! ;-)
geposted Tue 08 Jul 08 @ 8:10 pm
When you looking to have it finished?
geposted Wed 09 Jul 08 @ 11:00 pm
... like a ticking time bomb that i want to explode...
geposted Thu 10 Jul 08 @ 4:42 am
Great work ! Would like to check out this one when its done !
geposted Sat 12 Jul 08 @ 1:56 pm
JeremK wrote :
Just to let everybody know, next version of the skin resizer will let everybody change the background of the browser part.
So if you don't like that batman picture, or if Format takes it away and you want it back; the resizer will let you edit the browser graphics.
cool!
Will this work with all skins?
geposted Mon 14 Jul 08 @ 10:54 am
Almost every skin. If you want me to test a specific skin, send me a PM and i'll tell you if it works or not.
geposted Mon 14 Jul 08 @ 1:05 pm
Is there a way to add more buttons or another sampler box. I DJ for a few radio stations and it would be nice to have each stations samples in there own sampler, that way I would not have to keep changing them.
Thanks,
Skipper
Thanks,
Skipper
geposted Tue 15 Jul 08 @ 2:30 pm
HOT!! ;) Skinmaster in action ;)
geposted Tue 15 Jul 08 @ 5:43 pm
Yeeeeeeeeeeah!!!
geposted Wed 16 Jul 08 @ 6:28 am
