i know there was a topic about this already but im just asking again can you really use serato's vinyls with the software.Cnt get the Numark virtual vinyls anywhere unless you get them from NUMARk.com. i like the color serato vinyls they sell ones they have and guitar sells them for like $10 so i wanna make sure im not wasting money. So i need someone who is using them to help me. I know they are different but how much of a difference is it.
geposted Sun 22 Jun 08 @ 12:25 am
VirtualDJ v5.1 Pro can read SSL vinyl/CD by using the noisemap engine.
geposted Sun 22 Jun 08 @ 4:06 pm
Where are you located you can find your nearest dealer on Numark.com by entering your zip code :
http://www.numark.com/sales/index.php
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Kind Regards
Simon Bangs
geposted Mon 23 Jun 08 @ 1:04 pm
What version of the Serato Time code vinyls (First or Second) work with Virtual DJ and is it essentially the same quailty/response as using original Virtual DJ or Virtual Vinyl time code vinyl?
geposted Mon 23 Jun 08 @ 10:50 pm
Only the second edition of SSL vinyl was implemented in VirtualDJ v5.1 Pro and it's stupid to add the first version because this one was buggy.
geposted Tue 24 Jun 08 @ 5:42 am
djcel im using ssl time coded vinyl second edition and i jus installed v5.1 but im still having the same problem. i was only able to play 10-15 mins into my set and vdj stops reading the vinyl. what settings do i have to put it on? i tried clicking on the "noisemap" under time coded settings and its still doing the same thing. any recemendations i would highly appreciate it this is very frustrating
geposted Tue 24 Jun 08 @ 4:34 pm
Please try using a licensed copy , if you have a serial please add it to you profile so you can get a clean install file.
geposted Tue 24 Jun 08 @ 4:41 pm
what serato vinyl will work with virtual dj version 6.0.5? The second or first series?
geposted Wed 23 Dec 09 @ 3:34 pm
Only second edition CV02
geposted Wed 23 Dec 09 @ 10:23 pm
First eddition vinyls were years ago.. You wont find them because they dont sell them. Now to the question... Do serato vinyls work ?....yes.
geposted Wed 23 Dec 09 @ 11:45 pm
Hi guy i new to Djn etc, i currently use VDJ 7 with my RMX controller and two turntable. Can i use serato timecode vinyl for my VDJ7? if yes what version etc. thanks
geposted Sat 13 Nov 10 @ 6:55 am
What do you mean "what version"?? Serato only makes 1 version of timecoded vinyl..............CVO2.............
Huey
geposted Sat 13 Nov 10 @ 8:30 am
