Now that VDJ 5.1 has VCI-100 native support, does it work 100% as it should? Obviously there's no midi send from VDJ to make the lights work like they should but does the jog wheel function correctly:
- does the touch sensitive thing work as in traktor scratching (touch=pause;release=play)
- does the acrylic rim around the jog wheel work for pitch bend
My thoughts are that if VDJ had 100% support with the VCI-100, they would sell many more copies as this is proving to be a very popular controller and VDJ would be by far the best mixing software to use with it - especially if they added support for the thights, not only on the Vestax but also the other controllers, like the Behringer BCD.
geposted Mon 23 Jun 08 @ 6:15 pm
