Hey Y'all,
I've recently started using Virtual DJ 5.1 Pro and can't seem to toggle off of the scratch mode and into the Jog Wheel/Pitch Bend mode. I tried to configure a shortcut key for Vinyl Mode toggling but when I hit the defined key, the jog wheel continutes to play in Vinyl Mode(scratching). I prefer to use the jog wheel for pitch bending for mixing and would appreciate any help. Feel free to educate me on "mappers" and if this will be necessary.
geposted Mon 23 Jun 08 @ 6:21 pm
Are you sure that you have VirtualDJ v5.1 Pro?
geposted Mon 23 Jun 08 @ 6:24 pm
Positive...just checked Config->Info to verify... says "Virtual DJ version 5.1 Pro"
geposted Mon 23 Jun 08 @ 6:37 pm
I have just updgraded to Virtual DJ 6 and now I can't find the option to activate "Jog Wheel Mode". The "Scratch Mode" is activated by default now. Do you know where is the button to activate the Jog Wheel Mode? My specs: 15'4 screen laptop, dj console MK2, VDJ 6.0 Pro
geposted Fri 12 Jun 09 @ 7:59 am
as I workaround I have mapped a key temporarily to perform the action "vinyl_mode : set the jogwheel in vinyl mode (with scratch), or in cd mode (with pitchbend). 1 is vinyl mode (default), 0 is cd mode." so now is in "CD MODE"... still waiting for an answer - how to activate jog wheel mode?
geposted Fri 12 Jun 09 @ 8:29 am
CD is "jogwheel' (pitchbend) mode.
geposted Fri 12 Jun 09 @ 11:30 pm
