I want to move to VDJ for the video features, and today tested a copy of 5.1 Pro with my M-Audio Conectiv soundcard and MsPinky rev2 vinyls. The timecode seemed to auto-detect OK (although sometimes it thought the vinyl was rev1) but the playback point jumped around the entire MP3, audio was really poppy and it continued playing when I stopped the record. Tried various settings but nothing helped.
Should this setup work in theory, and if so could anyone suggest what may get it running properly?
Laptop is a gateway, 1.8ghz, 1gb ram, XP home SP2, and runs Torq-DJ fine.
geposted Tue 24 Jun 08 @ 7:10 pm
+ I should add that I've tried ASIO4ALL as well as the M-Audio ASIO driver.
geposted Tue 24 Jun 08 @ 7:15 pm
Hmm.. the latest n current demo is V5.07....
geposted Tue 24 Jun 08 @ 11:46 pm
i havnt been able to get torq vinyl to work properly. but looking at getting serayo vinyl - users have had more luck with it.
geposted Wed 25 Jun 08 @ 5:21 am
you'd buy serato vinyl instead of the official VDJ vinyl?
demo v5.0.7 doesn't have the 'PCDJ' timecode option, which I understand is the correct choice for Ms Pinky - or isn't that right..?
geposted Wed 25 Jun 08 @ 6:19 pm
Only 5.1 onwards support Ms Pinky vinyl, so the demo doesn't support it as it's only 5.0.7... so are you sure you're using 5.1? ;)
geposted Wed 25 Jun 08 @ 7:02 pm
Yep the copy I'm testing is definitely v5.1 Pro.
Is anyone using the Ms Pinky (or Torq - I believe it's very similar) vinyl successfully?
geposted Wed 25 Jun 08 @ 7:19 pm
Read this.
geposted Wed 25 Jun 08 @ 7:29 pm
Ta but I've already read that and it doesn't really help...
"- new engine "PCDJ" compatible with most miss pinky-based timecode records "
is kinda vague - is it supposed to work with my rev2 vinyls? Who knows?
geposted Wed 25 Jun 08 @ 7:34 pm
i still am unable to get my torq vinyl to work - the reason i was going to get serato vinyl is because they are easier supplied where i live. but am looking at buying vdj vinyl now. does anybody know their current availability? and possibility of sending to New Zealand?
geposted Mon 30 Jun 08 @ 3:27 am
