Hi,
I can't install new drivers for my DJconsole... Setup starts normally and asks for uninstalling the old drivers... "OK" (ABORT ends installation)... uninstallation runs normally and asks for a reboot at the end... "OK"... reboot. Now i start setup and it asks AGAIN for uninstalling the old drivers :/ it seems that the uninstall doesn't do anything. Hercules Folders and hercules tray icon are still there. Tryd the uninstall with "Remove Programms" but doesn't work either. Then i deleted the folders manualy and removed all hercules autostart entrys... but setup still trys to uninstall the old drivers.
I searched the forum 4 a solution but found nothing except some other users having the same problem...
HELP! don't want to format :(
THX 4 all posts
THX 4 all posts
geposted Thu 06 Jan 05 @ 7:19 pm
I have the same problem, have you sorted it yet or has anyone else??
I caused mine by having bot h drivers installed at once, now I have none!!
geposted Thu 17 Feb 05 @ 10:57 pm
