Hello, I keep getting "Error in the ASIO sound driver". Does anyone have a remedy for this? I purchased a brand new lap top today because I was getting the same message in my old laptop.
geposted Thu 26 Jun 08 @ 10:05 pm
You get that message when something is not right in your Sound setup of VirtaulDJ.
geposted Thu 26 Jun 08 @ 10:10 pm
Thanks. I am knew to Virtual DJ, where to I go to setup the sound correctly?
geposted Thu 26 Jun 08 @ 10:15 pm
Click on Config on your VV skin. Then click on the sound set up tab....hope that helps T
geposted Thu 26 Jun 08 @ 10:18 pm
Thanks, I did that. I have the iput set to timecodes (2 cd players). I have the output set to external mixer (I have a Numark DXM06) and have the sound card set to virutal vinyl. I go to timcode config click auto config and get the same error message that I get when I boot the sofware up. "Error in the ASIO sound driver".
geposted Thu 26 Jun 08 @ 10:26 pm
Try going here, it is ASIO4All's site and try using it instead of the default ASIO drivers...
geposted Thu 26 Jun 08 @ 10:30 pm
This is how I have my Timecode Sound set up.
Inputs: X2 Timecodes (TCV)
Output: External Mixer
Soundcard: ASIO Icon.
Soundcard(s)Maya <------------------------- Your's should be set to the VV Box.
VV may be slightly different to VirtualDJ, but I hope this works.
geposted Thu 26 Jun 08 @ 11:13 pm
This is not possible in this case VV uses a different technology.
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialis
Numark Alesis Europe Ltd
geposted Fri 27 Jun 08 @ 3:39 am
You need to set :
Card : Virtual Vinyl
Then go to performances and choose auto latency try now.
If you have no luck please contact me at sbangs[at]numark[dot]com and i can send you a patch i have been working on.
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
geposted Fri 27 Jun 08 @ 4:07 am
