The Mac OS X 10.5.4 Update is recommended for Mac OS X 10.5, 10.5.1, 10.5.2, and 10.5.3 Leopard. It includes general operating system improvements that enhance the stability, compatibility, and security of your Mac.
For information about security updates, please see this article.
Products Affected
Mac OS X 10.5.1, Mac OS X 10.5.2, Mac OS X 10.5, Mac OS X 10.5.3
Important: Read below before installing.
* It is recommended that you back up your system prior to installing any updates.
* The installation process should not be interrupted, even if the progress bar remains unchanged for several minutes. If a power outage or other interruption occurs during installation, use the standalone installer (see below) from Apple Support Downloads to update.
* You may experience unexpected results if you have third-party system software modifications installed, or if you've modified the operating system through other means. (This does not apply to normal application software installation.)
* If issues occur during installation--for example, if Software Update quits unexpectedly--please see this article.
Installing the update
To update to Mac OS X 10.5.4, use Software Update or the standalone installer. You only need to use one of these methods to update your computer.
Software Update
Choose Software Update from the Apple menu to automatically check for the latest Apple software using the Internet, including this update. (Software Update might have linked you to this article to learn more about the update.) If your computer is not up-to-date, other software updates available for your computer may appear which you should install. Note that an update's size may vary from computer to computer when installed using Software Update. Also, some updates must be installed prior to others, so you should run Software Update more than once to make sure you have all available updates.
Standalone installer
Download the update installer and run it manually. This is a useful option when you need to update multiple computers but only want to download the update once. These versions of the standalone installers are available from Apple Support Downloads.
The Mac OS X 10.5.4 Update is recommended for all versions of Mac OS X 10.5 through 10.5.3.
* The delta update lets you update from Mac OS X 10.5.3 to 10.5.4
* The combo update lets you update from Mac OS X 10.5, 10.5.1, 10.5.2, or 10.5.3 to 10.5.4
Additional Information
What's included?
The 10.5.4 Update is recommended for all users running Mac OS X Leopard and includes general operating system fixes that enhance the stability, compatibility and security of your Mac.
General
* Includes recent Apple security updates.
* Resolves an issue with saving and reopening Adobe Creative Suite 3 files on a remote server.
* Includes additional RAW image support for several cameras.
* Addresses an issue that may result in a partially installed X11 application.
* Improves L2TP VPN client reliability.
AirPort
* Addresses AirPort reliability issues with 5GHz networks.
* Addresses AirPort issues that may result in slower performance in Logic Studio or MainStage.
iCal
* Improves overall iCal reliability for meeting requests, cancellation notices, delegation, and syncing with iPhone.
* Resolves an issue that prevents deleting an iCal event without notifying the creator.
* Addresses an issue in which events in all calendars affect availability. A checkbox now enables information-only calendars to be transparent from free/busy lookups.
* Resolves a UI issue preventing delegated calendars from showing up as a separate window.
* Addresses an issue with copying and pasting attendees from one event to another.
* Resolves an issue in which iCal may not delete events after a specified time interval, even when set to do so in iCal preferences.
* Addresses an issue in which To Dos cannot be marked private.
Safari
* Addresses a potential performance issue when loading secure web pages.
* Resolves issues that may be encountered when accessing secure web pages with client certificates that reside on a smart card.
Spaces and Exposé
* Addresses an issue in which switching from a space with a Finder window keeps the Finder as the active application instead of the application residing in the destination space.
* Fixes an issue in which dragging an application from the list of application assignments in Spaces System Preferences does not assign the application to the desired space.
* Resolves an Exposé issue that may result in only a subset of windows being shown.
geposted Tue 01 Jul 08 @ 8:12 am
Thanks simon for the info;)
geposted Tue 01 Jul 08 @ 8:25 am
Its about damn time they fixed the airport...
geposted Tue 01 Jul 08 @ 7:22 pm
