it's just happened
"Tipo evento: Informazioni
Origine evento: Application Popup
Categoria evento: Nessuno
ID evento: 26
Data: 15/07/2008
Ora: 0.58.33
Utente: N/D
Computer: DESKTOP
Descrizione:
Popup dell'applicazione: virtualdj.exe - Errore di applicazione : L'istruzione a "0x00490fa9" ha fatto riferimento alla memoria a "0x019ff384". La memoria non poteva essere "read".
Fare clic su OK per terminare l'applicazione
Fare clic su Annulla per eseguire il debug dell'applicazione
Per ulteriori informazioni, consultare la Guida in linea e supporto tecnico all'indirizzo http://go.microsoft.com/fwlink/events.asp. "
Going to link it shows me this:
"Details
Product: Windows Operating System
Source: Application Popup
Version: 5.0
Symbolic Name: status_log_hard_error
Message: Unable to Load Device Driver : device driver could not be loaded.
Explanation
The program could not load a driver because the program user doesn't have sufficient privileges to access the driver or because the drive is missing or corrupt.
User Action
To correct this problem:
Reinstall the program to restore the driver to the correct location.
If these solutions do not work, contact Product Support Services.
Version: 5.2
Symbolic Name: STATUS_LOG_HARD_ERROR
Message: Application popup: %1 : %2
Explanation
User Action
Ensure that the program user has sufficient privileges to access the directory in which the driver is installed.
If these solutions do not work, contact Product Support Services."
What do you think??
ID evento: 26
Data: 15/07/2008
Ora: 0.58.33
Utente: N/D
Computer: DESKTOP
Descrizione:
"Details
Version: 5.0
Explanation
User Action
Version: 5.2
Explanation
User Action
What do you think??
geposted Mon 14 Jul 08 @ 6:02 pm
Explanation
Explanation
You have a problem with one driver but I don't know which one. I would say the video driver.
geposted Tue 15 Jul 08 @ 9:24 am
I've just reinstalled both audio driver and video driver.
I'll tell you what happens.
If you are interested, I contacted Microsoft as well and they said me:
"It would seem that the program reads a wrong memory address on the RAM.
The causes could be different, it could be a corrupt file or an unexpected block of the system which has generated this problem.
You could try to do a clean of the ram by specific programs.
If this doesn't work, try to reinstall the program.
If this doesn't work too, you have to do a general cleaning of your pc (use ccleaner) and then defrag your hard-disk"
geposted Tue 15 Jul 08 @ 11:20 am
I did all I could do.
I used CCleaner, I reinstalled both audio driver and video driver but the issue is always present.
In addition, I had other crash:
Crash ID=03d24e25 (date=807162107, version=5.1 Pro, build=510, thread=DSOutputQuad, dump=def9d95d, excode=c000008e (0))
Crash ID=03943005 (date=807171343, version=5.1 Pro, build=510, thread=Main, dump=010d0043, excode=c0000005 (1,494c4300))
Freeze (date=807171343, version=5.1 Pro, build=510, thread=Screen)
Crash ID=038c300b (date=807180030, version=5.1 Pro, build=510, thread=Main, dump=00540108, excode=c0000005 (1,83a1ffd2))
Freeze (date=807180030, version=5.1 Pro, build=510, thread=Scan)
Crash ID=01813004 (date=807191956, version=5.1 Pro, build=510, thread=Main, dump=666d71ff, excode=c0000096)
Crash ID=0ce63004 (date=807222059, version=5.1 Pro, build=510, thread=Main, dump=666d71ff, excode=c0000096)
are they external crash as well??
What do you mean when you talk about "external crash"?
Excuse me djcel but you are my only reference point of VDJ:-)
geposted Tue 22 Jul 08 @ 6:38 pm
Yes external crashes too
It means a crash not in the VirtualDJ code but in an external code: Windows or DirectX or codec or plugins or mappers or ...
You have two freezes of VirtualDJ: Screen and Scan
excode=c0000005 : Access violation
excode=c000008e : Floating-point division by zero
excode=c0000096 :
excode=c0000096 :
geposted Wed 23 Jul 08 @ 2:34 pm
Maybe I found out the problem about driver.
2 days ago I changed my video card from Sapphire ATI9800pro to Sapphire ATI HD2600XT.
I tried to install driver which I downloaded by ATI support
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
but it doesn't work with my new video card.
So I downloaded driver from sapphiretech support
http://www.sapphiretech.com/us/support/drivers.php
and it works.
After that I noticed a strange thing:
since I downloaded this driver I don't have any longer this issue in
mmc c:/windows/system32/compmgmt.msc
section DISPLAY OF EVENTS->SYSTEM
Type event: Error
Source event: ati2mtag
Category event: CRT
ID event: 45062
Date: 24/07/2008
Hour: 11.17.28
User: N/D
Computer: DESKTOP
Description:
CRT invalid display type
Data:
0000: 00 00 00 00 01 00 5a 00 ......Z.
0008: 2c 00 00 00 06 b0 00 c0 ,....°.À
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
so finally I've understood that with Sapphire card it doesn't need to install the driver downloaded by the site ATI!!
All of that was by change because if I didn't change my video card, I'll never have found out the reason of my issue with VDJ
For now I thank you djcel about your support because you sowed a doubt in my mind.
For who reads this topic:
NEVER INSTALL DRIVER DOWNLOADED BY ATI SUPPORT FOR SAPPHIRE CARDS!!!
I'll tell you any news about that
geposted Sat 26 Jul 08 @ 6:09 am
You're welcome
I'm happy that you finally found the external origin of these crashes.
geposted Sat 26 Jul 08 @ 8:10 pm
Another little suggestion for all users:
Keep up-to-date the lame encoder for recording your mix in .mp3 file
http://lame.sourceforge.net/index.php
I noticed more stability after updating this tool (I had got an old version of 2005 year)
Enjoy!!
Enjoy!!
geposted Sun 03 Aug 08 @ 1:37 pm
