Hello VDJ community, I have been doing all the reading I can and there are no clear cut answers to my following questions about recording samples.
Sample recording & play back levels. Since I started using v5.0 & v5.1 I noticed that the volumes are very low on the samples. I have tried everything to get the levels up. I tried recording with the volume all the way up and nothing. I tried raising the gain and nothing. Has anyone figured out how to over come this issue?
Sample lengths, for some reason it seems like the newer versions of VDJ only lets you record samples at a very small lenghts. Is there anything we can do to change that?
Settings of a sample before recording it such as beat sync, does it matter if we set the beat sync or any other setting prior to recording? The reason why I ask is most of my sample are right on beat but there are a few that are way off. I record the same way everytime so i can not figure out why some of them are off.
Thank you for your time, DJ VooDoo.
geposted Wed 09 Jul 08 @ 10:31 am
I have the same problem with low levels when recording samples, i also like to know if anything can be done.
I've post this problem a few months back but nobody seems to have the answer.
Good Luck
Good Luck
geposted Tue 29 Jul 08 @ 9:33 am
