Hi
Im using vdj with a firebox soundcard and the vestax vci-100 along with a HP laptop.
VDJ worked great until I recently formatted my hard drive. Now I get crackles while moving the bass / treble / mid knobs. How can this be fixed?
Also I noticed that the bpm counter is pretty off analyzing songs at half or double speed (ex 79 becomes 158, 126 - 63 etc)
Never had these problems before...
So appreciate any help!
geposted Sat 12 Jul 08 @ 6:38 pm
i had this same problem.. i re-installed it and it worked fine.
geposted Mon 14 Jul 08 @ 8:12 am
Thanks for the reply..! Just one question before I re-install,
Will I have to scan all my songs for bpm again? (I have roughly 5000 tunes and it took me days to get their bpm's last time...)
geposted Mon 14 Jul 08 @ 6:19 pm
Will the bpm's be saved anywhere???
I have a gig 2night and need to know.
Thanks
Thanks
geposted Wed 16 Jul 08 @ 6:48 am
I have the same problem (crackles)!
Re-installing does not work well for me.
Let me know how to fix it!
geposted Wed 30 Jul 08 @ 9:41 am
Hello again
I still havent found a solution. Plz enlighten us if u have a clue of how to fix this.
Thanks
Thanks
geposted Tue 19 Aug 08 @ 2:35 pm
If you are using the Safe Mode or Overclock (checked) then uncheck them. If you are using ASIO drivers make sure the Ultra Latency is checked on the Soundcard Setup tab.
Last, in Windows, right click the desktop, go to properties, click Settings tab, click Advance button, click Troubleshooting tab. Move Hardware Acceleration slider to the right 1 position.
Now what about the crackles ?
geposted Tue 19 Aug 08 @ 4:14 pm
Thanks dude!
Love it
Love it
geposted Mon 25 Aug 08 @ 3:44 pm
Didnt help : (
Is there a way to keep the analysed bpm's when re-installing?
geposted Tue 26 Aug 08 @ 12:01 pm
Well maybe a legal copy of VirtualDJ then ?
geposted Tue 26 Aug 08 @ 12:52 pm
Hi MR DJ's,
I just bought a Sony Vaio CR model with a MIcrosoft Vista (32bit). And I wanna buy a Virtual DJ Software. My friend show me the demo and i'm on 20 days trial on my desktop right now. I'ts so awesome!!! I compaired the Serato to my trial version, WOW Virtual DJ is much way better
What kind of version that I need to buy. What is the difference between Virtual DJ pro and Virtual DJ 5.2 trial version and 5.0 rev 6 (which is my friend has)?
Thanks
heymrdjLa
Thanks
heymrdjLa
geposted Wed 27 Aug 08 @ 9:37 am
heymrdjla2373 wrote :
Hi MR DJ's,
Thanks
heymrdjLa
Thanks
heymrdjLa
Please do not saturate the forum with the same question several times. I answered you in the first place you posted. Thanks for understanding...
geposted Wed 27 Aug 08 @ 10:01 am
Ok I do apologize! Its my first here and I just wanna make sure that I will buy the right product.
thank you and I do appreciate for your time
geposted Fri 29 Aug 08 @ 4:32 am
