Take a look to my skin special for TC users (available in 4 colors)
geposted Mon 10 Jan 05 @ 10:19 am
Nice work :)
geposted Mon 10 Jan 05 @ 5:46 pm
Good job!
geposted Mon 10 Jan 05 @ 6:49 pm
I like it !
Let me try a quick review.
I played with it tonight.
Clear design, looks like little "childish" with this Alien, remind me atomixmp3, but is ok.
A mix of hercules (alien), pcdj red, and objects from mixstation skins.
pros.
clear /easy to read/ not confusing, beautiful..
great (happy..) colors, i liked the green and red versions.
The vu-meters at the top, are great idea, and space saving.
cons.
Some bugs in the graphics: the vertical line in the centre of the waveforms is not in the right place.
Compared to other skins all my cue points showed wrong (maybe some ms)
Making new cue points based to visual waveforms has an error (offset)
Also, The Author/title is not well aligned with the blue lane.
Because its designed for Timecode, id' say there are still unnecessary object you can remove to save space (many buttons like skip etc.), even play/cue can be smaller (like a fat line)
Instead of buttons for loops etc, can you try a LCD display ?
Lets say using 2 -big- digits to show how many bars the loop is (loops from keyboard shortcuts)
The same for effects, etc.
The only i miss is the 3-band fader eq. Even you have ext mixer it can be very useful.
(i use the numpad in the keyboard for this.)
My advice: Move the sample buttons up, next to vu-meters and put a little eq fader (3 horizontal sliders) instead. The alien icon needs to be a little smaller to make room.
George.
pros.
cons.
George.
geposted Tue 11 Jan 05 @ 2:41 am
thanks george ...It's my first skin ....now I'm working again
geposted Tue 11 Jan 05 @ 5:07 pm
That's ok,
try my -colour- version of Pioneer 700,
I want to keep -and use- just 2 skins the pioneer as my powerful "remix" skin
and yours (the alien) as the simple "traditional" playing skin.
geposted Tue 11 Jan 05 @ 5:27 pm
Very good job!!!
Very clear and easy to read! Great with an external mixer & controller.
geposted Wed 12 Jan 05 @ 7:56 pm
quiero ser un dj muy famoso como hago para aprender bastante
pueden ayudarme
pueden ayudarme
geposted Thu 13 Jan 05 @ 11:23 pm
all we speak english here - pregunta en el foro español ..aqui solo se habla ingles
geposted Thu 13 Jan 05 @ 11:25 pm
can't exit out to change skin
geposted Thu 15 Jan 15 @ 9:21 pm
You bumped a TEN YEAR OLD thread?! You're using a TEN YEAR OLD skin?!
OMG! :-)
Are you using VDJ 7 or 8? In VDJ 7 it seems to load OK and you can exit by clicking the X (top right) as is standard in Windows.
The setting are accessed by the SET button (left of centre).
In VDJ 8 you'll have a problem because a lot of the code used in skins has changed over TEN YEARS. You can still exit, but the settings and other buttons don't respond - different code. If you need to load a different skin, the easiest way is to delete your settings.xml (where the skin choice is stored). That will reset everything.
If you really want this skin to work in VDJ 8 I can modify it for you.
OMG! :-)
geposted Fri 16 Jan 15 @ 5:56 am
