Hi all,
I've justed hooked up my RMX Console to 2 vinyl deks. The deks themselves work great, but I can only find out how to setup VDJ to work with timecoded vinyls. There must be a way to easily switch so that I can continue using my regular vinyls, but I just can't seem to find it.
I'm using version 5.1 Pro.
Thanx!
Kind regards,
Steven
Thanx!
Kind regards,
Steven
geposted Thu 17 Jul 08 @ 2:19 pm
Download Cioce v1.6 Cue skin (a very good skin btw) it was a Timecode Bypass button which, when activated will allow you to play regular vinyl.
Or you could create a keyboard short cut for the bypass.
You can download Cioce v1.6 Cue skin from the links below
(1280x768) -> http://www.virtualdj.com/addons/skin.html?id=4086
(1280x800) -> http://www.virtualdj.com/addons/skin.html?id=3196
Check out This post for more info.
geposted Thu 17 Jul 08 @ 2:27 pm
Thanx for the quick response!!
I'll give it a try asap!
BTW, is there a way to do this without the skin? (just out of curiousity :))
Kind regards,
Steven
Kind regards,
Steven
geposted Thu 17 Jul 08 @ 3:54 pm
As mentioned above, you could create a keyboard shortcut.
Look under setting in vdj>>keyboard shortcut>>press add>>turntable>>timecode_bypass n select a key for ur shortcut.
geposted Thu 17 Jul 08 @ 4:17 pm
