Okay, I have Vitual DJ Pro.
I have The laptop.
The internal soundcard
& a USB soundcard...
I got the main soundcard to play out of the speakers...
and the usb soundcard will sound to the headphones...
But i dont know how to switch to the Speakers from the Headphones...
Example:
Im playing (IDK) uhmm.. In this club - Usher, and its playing out the speakers....
I have London Bridges - Fergie sync'ed up & on a 4loop on the headphones...
How would I switch it so fergie starts playing to the speakers (maybe mixing it out) to start
hearing the next song on the headphones and so on....
I dont have a external mixer or turntables...
Ive tried everything!
someone please help!
I have The laptop.
Example:
geposted Tue 22 Jul 08 @ 12:43 am
did you already go into config and sound setup to make the right selections for how you want it to operate?
geposted Sat 02 Aug 08 @ 7:50 pm
You don't need two sound cards, just stereo spliter and you will config your sound card from config setup.
In this way you will play a mono sound but if you do that just for your self it's ok, becouse you will not see a diference betwen stereo and mono.
Good luck.
Good luck.
geposted Sun 10 Aug 08 @ 9:23 pm
