I just got my settings running the system smooth.
but when i activate the sonique plugins i get a poppy crackling sound when using them. same when i open an internet browser? Cpu is around 30-40% during soniquie
Solutions?
NVIDIA 8400m GS processer 256mb dedicated.
3gb ram
1.7 centrino duo
Vista Ultimate
Solutions?
3gb ram
1.7 centrino duo
Vista Ultimate
geposted Tue 22 Jul 08 @ 10:46 pm
Disable Vista sound enhancements: http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=1373474&SiteID=1&pageid=1
Disable the UAC: http://www.vista4beginners.com/How-to-disable-UAC
Modify the default power saving power plan: Click Start, type Power Options in the Start Search box, and then click Power Options in the Programs list. If you are prompted for an administrator password or confirmation, type your password or click Continue.
2. Click High performance. Doing this got rid of the skipping every 2 minutes skipping/popping.
FYI, I have the 8400GM 128mb card in my laptop. After doing that I would still have the occasional skip/pop. It would seem to happen worse if I had a video playing in the small window, in Virtual DJ or scrolling up and down on a webpage / song list. That crazy thing is it is intermittent. I.E, not a single skip on Friday night, nothing but problems on Saturday. I reinstalled Vista, clean. No extra software but Virtual DJ. It seems to be working fine. I need another couple weekends to make sure its working.
-David
-David
geposted Fri 25 Jul 08 @ 8:26 am
I found out the audio skip issue in Vista is caused by the Nvidia powermizer software. On some computer models, sometimes it can be fixed by a BIOS update or video driver update. Worse case you may need to turn off the Powermizer software. DPC latency checker would show spikes above 53000us with powermizer on. After disabling it, I am now in the range of 1500us. *Caution, turning off Powermizer could cause your video card to overheat*
Mine is at 82c, it's a few degrees hotter then with Powermizer on ~78c. The Powermizer tool is only for Vista. The Nvidia control panel software allows you to turn it off in XP.
Powermizer disable tool for Vista:
http://forum.notebookreview.com/showthread.php?t=273276
DPC latency checker:
http://www.thesycon.de/deu/latency_check.shtml
Download TechPowerUp to monitor GPU mhz and temp:
http://www.techpowerup.com/downloads/
Sources:
http://forum.notebookreview.com/showthread.php?t=252235
http://forum.notebookreview.com/showthread.php?t=252552
-David
Sources:
-David
geposted Thu 14 Aug 08 @ 9:40 am
