Hey ppl.
I was just wondering if the M-Audio fast track pro will work as a interface for Virtual DJ time code set up.
http://www.dmention-dj.com/produit-an.asp?num=390
Thank you.
Thank you.
geposted Wed 23 Jul 08 @ 3:49 pm
Yes, it will.
geposted Wed 23 Jul 08 @ 3:51 pm
Thanks, I was also wondering, i was told that the in's are 2 channels and if used it will have to be in mono. How would that work. and if so can you explain the set up
Thanks once again.
Thanks once again.
geposted Wed 23 Jul 08 @ 4:13 pm
Yes, you have 4 mono inputs (RCA). However, if you use the left/right from one source, you have 1 stereo input. If you do that with the other side, you now have 2 stereo inputs. So, you will be able to hook up 2 turntables or 2 CD players, with no problems.
geposted Wed 23 Jul 08 @ 4:24 pm
Im sorry but where do the 4 mono inputs come from? there is 2 XLR or TRS and 4 mono outputs. Still very confused
geposted Wed 23 Jul 08 @ 4:32 pm
I'm sorry, apparently I am confused also. I am thinking of another sound card. My previous post was wrong. If you are not using TCV or TCCD, you can still use this card. I found a demo for you, check here.
geposted Wed 23 Jul 08 @ 4:46 pm
LOL thanks man but yes i am using TCCD thanks for your help
geposted Wed 23 Jul 08 @ 6:06 pm
you can't do time code with the fast track pro because you only have one set of stereo inputs in analog, the other inputs are digital.
geposted Wed 23 Jul 08 @ 9:22 pm
You can use a Hercules MK2 or Maya 44. Both are USB.
Syberman
Syberman
geposted Thu 24 Jul 08 @ 5:55 am
sorry my mistake, you can do single time code only with the fast track pro
geposted Thu 24 Jul 08 @ 11:39 am
What is the most equal interface to the Virtual Vinyl that will work well with VDJ and Vista 32? I see the ESI Maya44 USB is only $109 and their website has ASIO drivers for Vista 32. Does anyone have experience with the ESI product using timecoded vinyls, VDJ, and Vista 32?
geposted Fri 25 Jul 08 @ 3:06 pm
I have heard great things about the Audio 8, check here.
geposted Fri 25 Jul 08 @ 3:10 pm
The equivalent of Virtual Vinyl soundcard is a serato box OR Audio 8 DJ. (Just look at the price: VDJ price + soundcard =? and compare to packs like VV and Serato)
geposted Fri 25 Jul 08 @ 3:19 pm
The Audio 8 dj interface is readily available for $400 and from reviews of the VV interface, much better. So the Audio 8 dj used for Traktor seems like a safe bet for use with VDJ and Vista 32.
How about Stanton's Final Scratch interface for $275? They have no mention of compatibility with Vista 32 on their website. Does anyone know if the Final Scratch interface with work as well as Audio 8 dj with VDJ and Vista 32?
geposted Fri 25 Jul 08 @ 4:57 pm
Audio 8 Dj user experience
https://virtualdj.com/forums/93445/General_Discussion/First_experience_of_Audio_8_DJ.html
geposted Fri 25 Jul 08 @ 6:56 pm
Can the numark dj i/o multichannel audio interface be used with vdj8
geposted Sat 12 Jul 14 @ 8:49 pm
I've tried twice and the Numark DJ io is crap, outdated drivers and it's 32 bit.
geposted Mon 21 Jul 14 @ 11:12 pm
will numark io work with win 8.1
geposted Mon 15 Dec 14 @ 4:28 pm
