I am a new user to VDJ and have just installed the Mac version of the program. I read some other posts about mac skins and am still not clear as to how many skins I can actually get on my mac. I see
one skin at the bottom of the skins download page where you get an option of PC or Mac. Is that the only skin available to mac users. I asked some other local DJ's I know who are using macs and they
said they have had a hard time with the skins on their macs too.
I read on another thread that you can download the PC version and play it in bootcamp. I bought a mac so I wouldn't have to run windows so that really isn't an option I like. The program is great with the skins there are already on it but would be nicer if us mac users could use all the cool PC skins or at least have a handful of skins that we could change to.
Any help would be greatly appreciated,
Thanks,
Thanks,
geposted Mon 28 Jul 08 @ 11:33 pm
Hi there, do read here.
geposted Tue 29 Jul 08 @ 5:22 am
Not all skins have been made available for Mac. :-(
If you have PC, you can download the skin on the PC, install the skin, and then get the zip file of the skin to use it on Mac.
And you can do the same with BootCamp.
geposted Tue 29 Jul 08 @ 5:34 am
Yes suprdave, pls read on the link that were given n there is the instruction how to zip from pc to mac;)
geposted Tue 29 Jul 08 @ 6:17 am
Thanks guys. I did as the prior thread recommended and it was actually quite easy. Since it is fresh in my mind I will put an easy recap for anyone else that might like skins on their mac.
I went to work and on my windows computer there here is what I did.
1) Download and install trial of VDJ
2) Download and install the skins you want. ( I picked 7 random skins )
3) Go into the skins folder
4) Copy the .zip files for the downloaded skins onto a thumb-drive. ( They are already in .zip format so no need to compress )
I got home on my Mac and this is what I did.
1) Copy the .zip files for the skins that were previously copied onto Thumb-drive
2) Paste them to the Documents>Virtual Dj> Skins folder ( Exactly as they are in the .zip format )
3) I closed virtual Dj program and re-opened it.
4) Select Config>Skins and there you have it. New skins for Virtual Dj on your mac.
Sweeeeeeeet........
Sweeeeeeeet........
geposted Tue 29 Jul 08 @ 10:14 pm
Nice feeling ain't it..njoy mate;)
geposted Tue 29 Jul 08 @ 11:37 pm
Does this only work for the Pro version? I've downloaded 7.0.4 VirtualDJ Home and there is no VirtualDJ or Skins folder in my Documents folder.
geposted Mon 23 May 11 @ 3:57 am
Skins and addons are reserved to Licensed registered users only. You need to purchase one of our dj software products (Broadcaster, Basic or Pro Full) to activate these features.
geposted Mon 23 May 11 @ 7:14 am
how do i get skins for my mac??
geposted Thu 30 Jun 11 @ 4:06 am
You register you license and then download from this site.
This is an old topic from 2008 btw!
geposted Thu 30 Jun 11 @ 6:28 am
