Last night at my gig a very strange thing happened with VDJ & the xponent controller.
After about 5 hours into my job I back cued using the wheel for player 2 and then went to press play and nothing moved, no music but the left side (deck 1) was playing fine and all functions worked good. The only thing that actually worked on Deck 2 was the wheel. After non stop tapping buttons the right deck started working fine but I'm sure it wasn't from tapping the buttons, this was after about 4 minutes of not working. I had to throw the next song into deck 1 when it's song finished. that worked fine as well. Gets worst... After the next song I put a song in deck 1 since deck 2 is working now and cue it up using the wheel, matching the beat, etc and when I was ready to play it it did the same problem as deck 2 did. So I had to do the exact same thing as before with the other deck to keep the music going. Deck 1 never came back functional... I decided to open another session of VDJ while the 1st was playing a song but when it opened an ASIO error message popped up with a loud windows alert. luckly I had a laptop on hand so I could restart VDJ without losing my dance floor and the embarressement. I didn't reboot the computer, I only closed VDJ and restarted the program right away and it worked fine for the rest of the night(2 hours). Any ideas of what happenned? Is there any know bug with this? I've been using the xponent with VDJ since November and have never had this happen.
Funkmasterfrank
Funkmasterfrank
geposted Tue 29 Jul 08 @ 11:10 am
this what you need to do have a next VDJ open confg the same way as the other one and you won't get ASIO error message popped that's why you got this error it was not setup.
geposted Tue 29 Jul 08 @ 1:12 pm
The message appeared before VDJ completely opened so how can I configure it to not show the message and just open normally? Shouldn't the 2nd one be the same as the 1st one as it's always setup that way...
Funkmasterfrank
Funkmasterfrank
geposted Tue 29 Jul 08 @ 4:34 pm
