Hi,
I am trying to make my new RMX to work with VDJ but no luck so far.
Here are my settings :
imac 24inch. running 10.5.4
Did update the RMX driver.
here my config in VDJ :
INPUT : none
OUTPUT : headphone
SOUNDCARD : Dj Controle RMX
Message : Error in the sound driver of core audio
I also try :
INPUT : none
OUTPUT : headphone
SOUNDCARD : 4 out card
DRIVER : Dj Controle RMX
Im sure this is simple, please advice.
INPUT : none
OUTPUT : headphone
I also try :
INPUT : none
OUTPUT : headphone
geposted Wed 30 Jul 08 @ 8:05 am
Try to plug the RMX in a diferent USB.
Good luck
Good luck
geposted Wed 30 Jul 08 @ 8:45 am
From http://ts.hercules.com/it/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=6
How can I verify that my DJ Console RMX is correctly installed on my MAC computer?
http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
How can I verify that the DJ Console RMX is working correctly as a MIDI controller?
http://ts.hercules.com/faqs/eng/her_eng_00352.pdf
geposted Wed 30 Jul 08 @ 8:59 am
was the damn usb, told you was going to be simple. TyVM !
geposted Wed 30 Jul 08 @ 2:47 pm
i have the same problem but i have the limited editon. until this thing is solved i wont upgrade to pro version. any idea?
thanks
thanks
geposted Thu 07 Aug 08 @ 4:26 am
i have the same problem as you Vaxhu i just want to work with the limited edition
but because of the sound driver error i cant do anything
my mac can read the Hercules RMX and i can start virtual dj but i can not play songs...
geposted Wed 13 Aug 08 @ 2:46 pm
