Whats new?
geposted Thu 31 Jul 08 @ 9:13 pm
Frankim3 wrote :
Whats new?
Seek and Ye Shall Find
External Devices:
Hercules RMX (improved) <------------ I wouldn't say so
Denon HS5500
Denon S1200
Denon HD2500
Denon HC4500 (improved)
Audiophony Mix
Audiophony Play
New commands:
"smart_scratch"
"browser_back"
"browser_enter"
"effect_slot_unscroll"
"video_fadetoblack"
Bug fixes:
Timecode: Silence & Stereo sliders are now correctly refreshed with Auto-Config
fixed crashes in Timecode Config with RMX (Mac)
"Asio" error message corrected (MAC)
crash with audio record in mp3 (MAC)
fields in the broadcast interface (MAC)
tracklisting.txt file not listed anymore under History (MAC)
the BPM tag is now correctly displayed on the File Info window (MAC)
First fix with the VV box warning when you close VirtualDJ (MAC)
Vista UAC crash (PC)
crash with search should be fixed now (PC)
crash with "No Timecode signal found" window fixed (PC)
crash with video recording when video module was disable (PC)
fixed crash with multi plugins (PC & MAC)
Retrieved from https://virtualdj.com/wiki/index.php/VirtualDJ_History
geposted Thu 31 Jul 08 @ 9:43 pm
what is "smart_scratch" ?
geposted Fri 01 Aug 08 @ 2:05 am
smart_scratch : Enable/disable smart scratch (auto mute backward scratch)
Thanks to DJcel for info ;)
geposted Fri 01 Aug 08 @ 2:57 am
How can I enable this new option??
geposted Fri 01 Aug 08 @ 6:37 pm
It would be my guess that you would just want to setup a keyboard shortcut for it. That'll be what I'm going to try ;)
geposted Sat 02 Aug 08 @ 10:56 pm
Is smart scratch just on PC? I didn't see that option on Mac.
geposted Sat 02 Aug 08 @ 11:59 pm
Hmmmmm...Dunno.
geposted Sun 03 Aug 08 @ 12:11 am
BTW, I set a keyboard shortcut for smart_scratch and it works as described. When you click the "add" button under keyboard shortcuts, it's under the "turntable" category (I chose CTRL+S). Happy skratchin' ;)
geposted Sun 03 Aug 08 @ 12:43 am
What are the Denon-4500 improvements and do they apply if I use jpb mapper ?
I'm quite happy with 5.1 at the moment, but if it 'refreshes' the display when you switch between CD/VDJ i'll expediate the install !
geposted Fri 15 Aug 08 @ 3:55 am
The jpb HC-4500 mapper has been updated again, loads of changes. Brilliant!
geposted Fri 15 Aug 08 @ 6:45 am
Improvements/changes to the native HC4500 support will not affect the mapper. However due to changes to the SDK for the HC4500 in VirtualDJ v5.2, you will need the updated version from https://virtualdj.com/addons/tools.html for it to work.
Earlier versions of the mapper will not work with VDJ v5.2 and the new v1.2 version of the mapper will not work with versions of VirtualDJ prior to v5.2
geposted Fri 15 Aug 08 @ 12:33 pm
Thankyou. I will try 5.2 with new mapper tonite.
geposted Wed 20 Aug 08 @ 6:43 am
Is this update going to be available with Numark Cue?
geposted Wed 20 Aug 08 @ 9:04 pm
You need to search the forums and look at the discussions on this issue... there is an entire thread that talks about your question.
geposted Wed 20 Aug 08 @ 9:15 pm
