I have a brand new 2.66GHz, 2GB Imac and every time I close Virtual Vinyl I get a warning window.
Warning
The system was unresponsive (%s).
Virtual Vinyl has performed a recovery, and should now work
ok again
Still, you might want to restart the software next time its convenient
enough for you to do so.
Has anybody else seen this warning window. I have the most up to date version of virual vinyl... Should I just go back to using the previous
version I bought. I didn't get this error until I hooked up my timecoded vinyls and mixer which are both made by numark. (tt200 and DXMPR).
Can anyone help? Everything is brand new.... Software and Hardware
Warning
ok again
geposted Thu 31 Jul 08 @ 11:51 pm
Are you using MAC OS Leopard?
There is a first fix in the version 5.2 and I hope it will be ok.
geposted Fri 01 Aug 08 @ 4:48 am
djcel, you should know that there is no v 5.2 of Virtual Vinyl... :-(
geposted Sat 02 Aug 08 @ 9:11 am
What do you mean a first fix? I went back to using version 4.3 just to check if the new equipment jacked it up, but it worked flawless and with no errors when closing. Any input on what to do or if I missed downloading something I needed. I downloaded version 5 today just to see if it was the system. Yes, I'm using Leopard 10. This fix you mentioned... Your saying this has already been done, right! I restarted my mac from scratch to see if it was something wrong wit the mac, LOL .... I'm going try the Virtual DJ 5 and get back to you.
geposted Sun 03 Aug 08 @ 1:03 am
Ok, I saw threads about version 5.2, but it's not available in downloads. Only version 5.07. Is this something that hasn't come out yet?
geposted Sun 03 Aug 08 @ 1:07 am
Sorry yes u are correct, atm only V5.07 is available for VV user.
geposted Sun 03 Aug 08 @ 3:49 am
hi friends i have the same problem :
Warning
ok again... what is this???
Warning
geposted Fri 06 Mar 09 @ 9:10 pm
i have 5.2.1? its ok for me...
geposted Mon 09 Mar 09 @ 11:18 am
