Yikes, it should not be hitting 70 C idle. 70 C is the upper threshold for what these Intel chips are designed to cope with (the mobile versions are reported by Intel to max out at 100 C so you've got some headroom I suppose). Have you ever overvolted the chip or anything? I'm currently 44 C idling, but the fan is pretty much off, and I would not expect it to even reach 60 C under load.
I have noticed though, a lot of Windows software depending on the sensors reports the temperature 10 C higher than the BIOS does.
geposted Fri 01 Aug 08 @ 5:51 pm
It's possible that it's a build up of dust, as I use this computer everyday in a number of locations.
How can I see the temperature reported by the BIOS?
geposted Fri 01 Aug 08 @ 6:23 pm
I think the bios temperature showing different is probably a fault in some of the older firmwares I used on a few machines. A lot of laptops bioses are limited anyway and you won't get any readings. Hopefully your bluescreen problem does turn out to be heat related and the cleaning of the fans sort it out, good luck.
geposted Fri 01 Aug 08 @ 6:41 pm
I haven't had a blue screen since I wrote the first post, but I have had two or three instances of the screen just going black.
Everything would seem normal, in terms of the computers activity but the screen totally black, ctrl-alt-delete does not help either, there is no way of recovering from it.
It happend today when I tried to open a small video file in WMP.
Anyone know anything about this?
geposted Sun 03 Aug 08 @ 2:40 pm
i had this msg 2 days ago i dont know why
im using dn-hc4500
HP DV6 4gb Ram cooling fan under the pc no problems till this shows up but no blue screen
Faulting application name: virtualdj.exe, version: 5.2.0.0, time stamp: 0x488b4594
Faulting module name: virtualdj.exe, version: 5.2.0.0, time stamp: 0x488b4594
Exception code: 0xc0000005
Fault offset: 0x0009b429
Faulting process id: 0x1324
Faulting application start time: 0x01cb3659a76f0f66
Faulting application path: C:\Program Files (x86)\VirtualDJ\virtualdj.exe
Faulting module path: C:\Program Files (x86)\VirtualDJ\virtualdj.exe
Report Id: 00d4f1cf-a274-11df-885f-b2cbd123dead
im using dn-hc4500
geposted Tue 10 Aug 10 @ 3:41 am
This version is very old (28 July 2008). You should register your version and update it to the latest one. There are many bugfixes since 2008 **LOL**
Heiko
Heiko
geposted Tue 10 Aug 10 @ 3:45 am
Great
Another 2 year old thread pulled up by an NLU that has no connection what so ever.
You are in the GENERAL FORUM.
Please start a thread of your own in the PC Tech forum below.
https://virtualdj.com/forums/20/PC_Version_Technical_Support.html
Topic Closed
Topic Closed
geposted Tue 10 Aug 10 @ 3:47 am
