Can someone tell me whats the difference between 5.07 and 5.2/5.2 ? I have 2 laptops with Maya 44 USB cards and both of them work great on 5.07 but with 5.1 or 5.2 the system is unreliable. sometimes the maya 44 usb is not recognized and if it is is, no sound comes out of the card (none of the lights on the output channels blink. ANd with timecode, it doesnt respond correctly, even when I do auto-config.
HOWEVER, 5.07 works 100% great without any issues. Is there something with 5.1 or 5.2 and the maya 44 USB sound card? is there a diferent sound card with 4 in and 4 out that I could use? maybe an mixer/sound card in one? I am lost because I am stuck at 5.07....
geposted Thu 07 Aug 08 @ 1:43 pm
To know what it's changed from 5.07 to 5.2 you should read this:
http://www.virtualdj.com/wiki/index.php/VirtualDJ_History (bottom of the page)
Maybe you should set "VDJ Timecode v4" rather than "VDJ Timecode v5"
Let's know if you fix your issue
geposted Thu 07 Aug 08 @ 2:06 pm
I have now tried everything with 5.1 and 5.2 and no change.. I'm sticking with 5.07 unless there is something I can do.. I think it has to do with the maya 44 usb as I have 4 of them all with the same issue on 2 different laptops...
geposted Mon 11 Aug 08 @ 10:17 am
