I Want to use my desktop to do a bpm scan of all my music files, where all this info is save?
Can I move those files to my laptop later??
DJ 5.2- Win Xp - Hercules MK1 Mixer
Thanks in Advance
Thanks in Advance
geposted Sat 09 Aug 08 @ 1:25 pm
There will be a file called "VirtualDJ Database v5.xml in your My Documents/VirtualDJ folder. Copy this one one over to your lappy when your scan is done.
If you are using an external drive, there will be no need to copy anything because it will already be on that drive ;)
geposted Sat 09 Aug 08 @ 2:50 pm
All my music is on a 500 GB external drive.
I don't need to worry about it?
Another question:
If a move a folder with music inside to another folder. I need to scan again???
How about the tags?
Thanks again
Another question:
How about the tags?
Thanks again
geposted Sat 09 Aug 08 @ 3:59 pm
No, you will not have any worries on an external drive; the database is in the root of the drive itself.
If you move things around, you can probably get away with recursing the music folder, then right-click and select "add to search db."
Happy scanning ;)
Happy scanning ;)
geposted Sat 09 Aug 08 @ 4:21 pm
