having problems when mixing videos. on 2nd screen. using full screen on a projector. the sound does a slight skip every now and then. only when using full screen mode. anyone else have this problem? or know a work around. using a song dual 2gig laptop so dont think its laptop power. and using djconsole rmx
geposted Mon 11 Aug 08 @ 8:25 am
if you go into hardware forum you will get loads of info on this warrior, it could be a number of things with just as many fixs, but make sure you have all the latest drivers first, this clears up a lot of problems and also check out your settings, some have more success than others... as in whether to use asio mode, as i say best to check out the other forum
geposted Mon 11 Aug 08 @ 1:29 pm
